ripp
182 FFAT
Hi,
So I want to do a timing check on my 182, as far as I know the procedure is like this: remove camshaft end caps to expose the grooves
Rotate the crank until the pin slots in the correct hole on the crank and see if the horseshoe tool slots in the cams with ease.
The thing is my 182 had an engine rebuild while back and now it has a 197 crank in it, so I was wondering if the pin hole in the 197 crank is in the same spot as the 182 crank and if not, what's the procedure of checking the timing?
Thx!
Thx!
