Claying - Which one, and how to......
  Shed.
Something else im guna try also, which clay kit should i go for ?
Also, how do you clay.....tare a bit off the bar and flatten it out and then drag it (rub it) across the paintwork...
megs clay .
wash the car and do it whilst still wet , you can never have too much liquid on the car , have too low can be a mess , rather than the quick detailer , use car wash stuff watered down .
break the clay bar into 3 pieces , i piece enough to do the whole car , drop it some hot water to soften 1st .
What is claying?
  Clio MK2 (1.2)
Nice will put a list ov stuff i need to order then, found some scratches on the clio that i need to get rid :(
  106 GTi
The newer Megs Clay Kit looks alot of money for what it is, Though the clay is quite good. I use that or the Sonus Green.
  Shed.
should i try a bar of sonus green then, and also am i allrite just say giving one pannel a wash at a time and then rubbing the clay with the soap suds.. ??
What sort of benefits will i be able to see ? i only bought the car in october and i think the stealer will have clayed it.
  Vectra 1.9 CDTi SRi 150
I bought the Sonus Green as recommended by Rich, quite a mild Clay, ideal for the first timer.
  106 GTi
Visually not alot, test the paint to see how much stuff is bonded to the paint. Can you feel a rough finish washing wont remove ?
Mix up some shampoo and water in spray bottle to use as the lube, after washing the panel spray it on. I use 2-4 capfuls in a 500ml sprayer.
  Skoda Fabia vRS
a dealer will NOT have clayed the car, the vast majority of valeters dont even know what it is
