Clio 1.4 engine stall
  Clio MK2
Hi there
I have Clio 1.4 16v the problem is the engine some times rough idling about 500 rpm and other comes to stall but when i press the gas pedal it runs good but when have to stop at junction or lights it stall some times and sometimes it runs smoothly and this problem occur whenever it's cold or hot . some times there is a problem and some times it's okay. I have cleaned throttle body and all sensors TPS ,Idle valve and MAP sensor. and I have tested all coils and it works fine .and for a reason I don't know my car won't connect at any diagnostic tool and no one knows why !!
could any one help with this issue
