I've got a full 197 head, i see the location the hole needs drilling too + ive got all the 197 inlets which have been re-drilled to take a phase 1 172 TB.You need to drill a hole in the cylinder head for the timing belt tensioner so it’s the same as a 1*2.
Lots of work. You need to use to the mk3 inlets as well. 1*2 will not work.
In essence i can run a full P1 loom, ECU etc with this setup
I think the point is, it’s a lot of work for how much benefit?
The hardwork is getting an ecu to run the cam sensor that’s on the 197/200 in a 1*2. The ability to run the full vvt is the reason why it’s worth doing.I think the point is, it’s a lot of work for how much benefit?
