Hi Guys.
With regards to my wife’s Clio mk3 1.2 ,16 valve ,
The car has a slight misfire (if the car is left for a couple of days on starting it up it really runs rough loads of white smoke ,this clears up once the engine warms up) I have put a code reader on and the error code comes back with P0130 (02 sensor bank 1 sensor 1) which suggests that the Lambada sensor is faulty , the code reader I’m using is only a cheap one.
I think I have got a injector on its way out which is corrupting any signals sent from the Lambada sensor that goes back to the ECU ,is the job to replace the injectors hard to do is there any steps mentioned in the forum that I could use ,and finally I apologise for rambling on I have only just joined the forum ,
