clio rs4 2016 brembo updates
  clio rs4 200
ciao ha tutti ho comprato e montato il kit brembo update sulla mia clio rs4 200
volevo chiedervi con questo kit ci sono montati i distanziali da 16 mm
se cambio cerchi levando i distanziali , che cerchi montano ?
  clio rs4 200
I already mounted everything but I wanted to change the rims to remove the 16mm spacers but I do not know if they touch the caliper
  Clio 197
I think if the offset of the new wheel is lower, and the same amount as the spacer width, e.g new alloys have 16mm lower offset and you are using a 16mm spacer, they should clear the calipers. What alloys are you looking at purchasing?
