www.colombo-bariani.com
They got couple of different profiles for F4R's. The one's advertized on their website is the one that I am using. Much better than Cat's. The same built quality as Schricks.
Strongly recommend them. I think the reason that they are not very common in the UK is the distributor problem. They are very well known in Europe.
yes
Idea for Yozza/K-tec etc. !?
yes
K-tec ---- not sure but by looking the profile I can easily say that it is one of the CAT's
Yozza ---- Schrick's
but drop them an email to be sure.
Price is around 700 € exc P+P for Colombos
yes
I TRIED speaking to them today ; they started patching me through as soon as they heard i spoke Englishfinally a lady told me i could please e-mail in English as she also did not speak English and wanted to get rid of me .
I'm interested in getting some y0z !
ok, well having spoken to them again today they are going to send us some more information and we are hoping to get set up with them in the next few days.
/y0z
Pretty sure The Jesus was running the '428 Cat cams which i also run. They are also billet cams so good build quality, and great to run on stock internals and ecu.
Cant imagine much difference between the '428's and equivalent Shrick's on back to back RR'd other then being a couple of quid more out of pocket !
i posted the info loads of times, try searching![]()
http://www.colombo-bariani.com/popup_dettaglio.php?lang=eng&id_prodotto=103
this is the data for the road medium .. C&B that is...
just searched for these specs, can't find 'em ....
@the Jezus ; have you looked at these C&B specs ? 280/286 i think... is'nt that a bit "wild" ? Does this mean that the power is more on top of the rpm range ?
not yet mate, not had a chance to, I'll look when I get home, as I'd like to compare them all. As for wild cams, basically if the lift is too high then you'll have valve clearance issues, but if the pistons are forged/pocketed you can time them back so they dont peak at such high rpm.
Hi frank,
Could you inform me when you have a price on posted to the Netherlands? Yeah I'm cheap, but maybe when the price is right we can buy 2 sets in one go.
And are you fitting them yourself?
Henk (fastchip) already told me these are good cams and the mild ones can be run with standard ECU and he could map them nicely. (10-15bhp) and ofcourse a big load of torque I hope![]()
Franx, I'll have a look, but if you look on catcams website, their 428's will run on stock internals, as will the model up from those, but I think after that the valve's touch the pistons, so you'd either need new ones, or have your machined with a crown to avoid this.
Best bet is speak to Andy at GDI, as I'm not sure at what lift point it becomes a problem, but I know he's used the whole cat range, so will have a damn good idea... certainly more than I will! lol.
