comma dot 4
hi guys i am getting my goodridge lines very soon just wondered if comma brake fluid dot 4 is any good for general road use and better than standard renault stuff many thanks
It looks like its quite good never tried it myself I'd always spend the few quid and use the Castrol Super response stuff £11 or so it is for a liter. Its got a higher boiling point for starters.
cheers mate i only would use for everyday fast road use not any track work so will the comma do on a bit of a budget..will it be better than standard mate
I forget the spec of stock stuff I don't imagine the'd be much in it stock stuffg is infact very very good just noone realises it.
brake fluid is brake fluid the majority of the time, just bang some in.
So long as fluid is fresh your good to go.
  RenaultSport clio 172 mk2
Thinking you'll notice some detectable difference in ordinary use between two brands of brake fluid is like thinking you'll notice the difference between two different brands of engine oil. Brake fluid is brake fluid. As long as its the product of a reputable company and meets the relevant technical standard it is brake fluid.
MRBILLYUK
  FF Jeden Osiem Dwa
I've used comma in the past and i've used castrol response .Like GordonD says , its like having 2 different kinds of engine oil , you can't tell the difference .
cheers mate i never go on tracks or ever will and only really have a good go on the b roads in summer but other than that just standard 172 driving he he...i will change mine every 2 years but what do reanult say for there standard stuff thought it was 4 years?
MRBILLYUK
  FF Jeden Osiem Dwa
^^^ Your right . Renault do recommend every 4 years or 72k .Personally and for the sake of a tenner i change mine every 12 months usually .
cheers mate thanks for that will do...going to go for the comma stuff dot4 hope i dont end up in a wall he he thanks for all your help on this guys..i will probably get it changed every year what would labour be on this is it less than a hour to bleed the system!!
