exactly as dink mentioned above stick the crossover in the dash and take wire through to the door by taking the plug which goes between door and car apart and drilling a small hole in the bottom of both sides and push the wire through
my crossovers are fitted in the plastic part under where the gearbox is.Loads of room in there. Cant even see them and make wiring easy. Well thats if you dont want them to be seen...
