Connecting xbox + freeview to VGA
DrR
  VW Golf GTD
I've found cables to connect my xbox to it no probs
but is there such a thing as scart to vga? none seams to have audi just visual only.
  172 Cup
VGA is video input so naturally it's going to be visual only. Unless I've missed the point of your post?!?
  Fabia vRS
the xbox360 vga cable has a vga plug and 2 phono plugs. you plug the vga plug into your tv/monitor, and the phono plugs into your amp or tv.
glad my rocket science degree is being put to good use ;)
DrR
  VW Golf GTD
must be s**t rocket science then, as i've said i've found an xbox one and i'm after a SCART to vga with audio ouputs.
Griff I want to connect the VGA to the pc monitor then the audio to some external speakers from a freeview box.
  172 Cup
http://www.js-technology.com/produc...id=33&osCsid=b1a0022c972a41ed241165b9dfd23860
Not cheap but you get what you pay for.
Compatible with RGB from any source, such as DVD player, Sky Digibox, Freeview box, or Digital Cable
Convenient connections to existing equipment - SCART input, 15-pin density and a half D-Type VGA output.
Audio is passed through without modification to ensure optimum audio quality.
Scart to VGA SyncBlaster Cable
· Connect RGB scart equipment directly to Plasma and LCD screens/projectors · Incorporates a full functional sync separator and amplifier · All essential components built into one neat lead · No additional power supply needed (for most applications)
Not suitable for monitors designed solely for computer use. (The screen must support a horizontal scan rate of 15.625KHz- most projectors, plasma and LCD panels do whereas CRT monitors dont)
DrR
  VW Golf GTD
so how come you can get component to scarts? but no the other way round?
