Coolant change
I've never managed to get it to take more than 4.5 litres to fill and it's supposed to take 7 litres.
I remove the bottom hose at the radiator, the heater hose where it enters the thermostat housing and the bleed screw.
What am I missing? I don't have an air lock so don't bother suggesting it.
  Ph 1 172
if i rememberrightly i connected mine all up again started the engine and the level dropped drastically so thats when i put the rest of the fluid in...hope that helps
i think mine only took about 5.5l, although i removed the thermostat to flush the block when i did mine - quite a lot of coolant was released from behind the stat housing. may be the 7l's just an overquote?
you'd need a gasket for the stat housing if you remove it - *think* it's 8200267272
or is there a drain plug for the block? perhaps mine's now 5.5l coolant:1.5l tap water:rolleyes:
ed. twigged - presumably the rest is in the heater matrix circuit
