In two years with F4R's Ive NEVER had a problem with air locks or the engine overheating, until now.
At the start of the month I had a few weird issues at Oulton Park, where the temp gauge would rise up past the max marking on the gauge, then come back down again, and repeat. I wasn't sure why it was happening as the car had been fine since replacing the clutch and re-bleeding the whole system to the book...
After the Oulton Park day I never had a problem until a few weeks ago, where the needle would go up very high under normal driving conditions very quickly, I.e. within 5-10 minutes of driving. Like the thermostat wasn't opening and it was getting hot quickly.
So I bought a new thermostat, and fitted a different (Known 100% working) coolant temp sensor. I flushed the whole lot with a hosepipe, including the radiator, then re-filled the coolant system. I undid the bleed screw on the side of the housing until there was a constant flow of fluid, numerous times, whilst topping up the reservoir. Ran the car upto temperature until the thermostat opened and the gauge stayed normal, just on halfway which is previously always was...
The car seemed OK to begin with for a day or two, but then it went back to its old ways - the needle going sky high, sometimes off the gauge entirely! For example a 10 minute drive over 4-5 miles would see the needle off the gauge, not even enough time for the thermostat to open! Ive had this on other cars where there has been an air lock near the temp sensor, but I even re-bled the system from scratch again and kept the same problems.
I wondered if the thermostat might be dodgy and Ive got a dud new one, but I removed it and checked it in a bowl of boiling water - it was perfect. I even tested the old one, which was fine too - so buying the new thermostat was pointless really..
After testing it I re-did the whole coolant process again, and it was OK when getting it up to temperature right after re-filling - the needle sat happily in the middle for nearly 35 minutes at various RPMs. That evening after driving it the same problems were back again - and Ive no idea how!
Anyone had anything like this before? As its starting to p*ss me off now...
