Martin_172
This cars doing my head in, its just not running right, thought it was the engine mounts so changed them all and problems still there so trying a few other ideas!
- if a driveshaft or both driveshafts were shot, would it cause the car to jerk when coming off the throttle or quickly hitting the throttle ( feels like a worn engine mount but all 4 replaced and not cured it!)
- should there be ANY play in the shaft at all? O/S driveshaft has a small amount of play at the inner side (where it goes into the gearbox) but only a slight movement when you shake it (kinda like a rattle if you know what i mean)
- I cant see because the cars lowered and ive not got time to jack the car up but when i touched the inner gaitor i came out with my hand covered in grease so im assuming its split, will this have already caused any damage?
