Cruise control problem
  1eight2
I tried to operate cruise control for the first time earlier and couldn't get the hang of it...
I pushed the button down and a green speedo symbol came up and allowed me to set a speed. However, once I released the button it just reset. If I push the top of the botton an orange which doesn't display any speed. I also have buttons on the right hand side of the wheel?
Sorry if this sounds noobish but i'm clueless and i'd love to use it with all the motorway miles I do...
  A3 2.0TFSI QUATTRO
Flick the switch for green light and it will show a speed your doing then press the r on your steering wheel and it will set to that speed
sbridgey
  disco 4, 182, Meglio
almost, flick switch, make sure your above 30mph,release all pedals, press the "+" button, that will set the speed, the "0" button will turn CC off and "R" will return to previously set speed
  1eight2
The minimum speed is around 20 mph....and using the brake or clutch will turn CC off. As Simon has said above, try that...if the CC doesn't stay on, your switch might have a problem...if it does (so you would need to keep the CC button held in on the dash...for CC to work) try this http://www.cliosport.net/forum/showthread.php?473165-cruise-control&highlight=cruise+control
I had same issue with mine when I got it. :)
Hope that helps.
Thanks for digging that out, works spot on now!
I could do a detailed guide with pictures if needed?
