cv boot
Not really unless there is cv grease all over the wheel, thats the only real give away
is it possible to see if it has split without taking the wheel off?
you can,its a bit tough but try to get under the car, or even better jack it up(support on axle stands!!!) and get someone to slowly turn the wheel while you try to look for a rip or tear in the boot. wont be easy though
as said before jack the car up (supported by axel stands obviously!!) turn the wheels to full lock and rotate and see if you can see a hole in the boot check to see if the clips at each end of the boot arent broken or loose causing the grease to come out that way.
