Dashboard lights keep going out with main lights turned on
  Renault Clio 182
I have a 182 that has an electrical fault. The centre dashboard lights, including the radio, come on as usual when you start the car, but go out if you put the headlights on or if the auto lights come one. I have had the ECU unit checked out be the recommended guys from the forum and that has been given a clean bill of health. I have replaced the earth strap from the gearbox to chassis, negative terminal to chassis cable and used a new relay to check out the 6 small relays that are also under the glovebox that are held in place by the ECU.
Any other places to go looking?
