I'll be getting 45's maybe 40's if i have to, i'll be revving to 7500 at the most.
Are you running carbs?
How much is the mega jolt system?
No, I have a megane 225 now, but I built a VX 2000cc XE powered westfield and had to convert the injection system on that to run carbs and converted to points based dizzy.
My conversion was to get rid of the electronic distributor and ECU off the vauxhall and replace with ignition set up (dizzy, coil, amplifier) off an 8V vauxhall cavalier which was carb fed. This didnt need any standalone management.
Megajolt isnt dear at all, do a google search or better still head over to
www.wscc.co.uk which is a westfield forum, but there are loads of topics on there about megajolt. There is a UK importer on those forums called bill shurvington who you could send a PM to. He is a top bloke and will help you out.
If peak power is at 7k, you will definately need 45/48s, as you will need close to 45mm choke size and the DCOE/DHLA 40s will only take a choke size of 36mm. DHLA 48s go up to 43 in choke size.
Bear in mind, its not what your car will rev to that you have to consider, its where you realistically expect peak power to be made.
I have a web link somewhere which will help you understand a bit more what I am rabbiting on about let me see if I can find it
