yeah def a good noticable gain its able to accel quicker also some may not believe but some how it made my valver with no mods except decat as quick as a 172 so im chuffed
a decat on an old clio like a vlaver is the best priced mod you can do
on the newer models 172s and 182 decats are slightly tricker as you need to bypass sensors and if you dont it can cause all kind of probs and running probs flashing dash board lights haha
So by fitting one of these will it make your ECU think that the emissions are to high and cut your power, or will it light up your SERV light or something?
Is there a way to bypass sensors to trick them into thinking nothing is at fault?
Quote: Originally posted by ozzyo99 on 15 September 2005
So by fitting one of these will it make your ECU think that the emissions are to high and cut your power, or will it light up your SERV light or something?Is there a way to bypass sensors to trick them into thinking nothing is at fault?Cheers.
Mk1 clios only have a lamba sensor in the fanifold/downpipe.
Wiht the mk2s you simply unplug the 2nd sensor...sorted
