Dell PSU
  Clio v6
Looking for a Dell Dimension 2300 PSU Part Number PS-5201-8D1
I believe these are proprietary PSU's. Perhaps someone may know of an adaptor cable to use a standard PSU?
Thanks for anything you can offer.
  Revels Mum & Sister
When you say Adaptor cable do you mean Internally?
I dont remember Dell using anything other than a 20 Pin AX adaptor to power the Mobo as its a standard, or using anything other than 4 pin Molex connectors for HDD and CDROM?
Usually they Spec stupidly sized PSU's as in physical dimensions!
  172 cup'd extreme
if its the mini ATX case its a normal sized , normal connectors PSU if its the scissors case then its a normal 20 PIN ATX connector but its a funny size.
you can get them on ebay for around £20
its the motherboards that wont fit in other case's
  Revels Mum & Sister
Most PSU's have the 4 Pin power Connector you are showing there. I think its another +12V
