difference
  Lots of Alfas
The dci 65 has a small turbo and no intercoller, the 80 runs a bit more turbo boost and has intercooler and different injectors. dci 80 also has a better gearbox similar to 172. The dci 100 has uprated turbo, injectors, intercooler, pistons, different intake but a crap gearbox.
  Evo 8 MR
I thought all Clio gearboxes were garbage including 1*2's?
It's the sole reason a friend of mine won't bite the bullet and buy a 172.
  BMW M4; S1000 RR
It's just remapped. You can buy a 65 and then for £300 get the same car that costed a few grand more..
Plenty of threads on here detailing differences on all the models including dci's.
  Evo 8 MR
Oooh, link?
Relatively speaking they're not great!
The DCI 80 uses the same box as the 172, just with longer ratios.
Would have thought the ratios would be shorter...?
  BMW M4; S1000 RR
Shorter ratios mean less top speed, better acceleration. Higher the number (as a ratio to 1) the shorter the gear.
The DCI's only rev to 4.5-5k rpm. If they had the same ratios as a 172 they wouldn't even be able to hit 100mph in top gear. So longer/taller gears are needed.
  Evo 8 MR
Seeing as they only need about 5k I assumed the ratios would be shorter but I see what you mean due to them having less power they need more time to build the speed. ;)
  Lots of Alfas
search for "dci differences" and tick the search thread titles and have a read through. Theres a few in the trade that dread the dci100 gearbox, theres been one or 2 posts on here with members that have had problems. To be honest the dci100s are quite rare. You can buy a dci 65 and get it mapped to around 80hp, the gearbox is very similar iirc. Im sures theres a few that have fitted a intercooler too.
