PH-QUICK
So basically had this for a long time but recently its been getting worse. Sometimes i'll try to select 2nd and the stick simply wont go down into the correct position, like if you were trying to go into reverse with out pulling up the lip, its as if there's something in the way of the stick.
This will also happen going into first sometimes, but then something it wont happen at all and everything will be normal.
So what's going to fix it? new gearbox oil?
