Divx ???
  A well built VW
I have Divx media centre or whatever its called
I have followed the simple instructions
1. Place blank disc in drive
2. Drag and drop file (checked to make sure it is a Divx file)
3. Burn - but this is never highlighted
What am i doing wrong or does anyone have a better way to do it ????
  Clio 172mk2
just burn it as a normal disk for files,
are u trying to play the disk on a external player?
what hardware is it etc
  SLK 350
I'm guessing he's trying to burn it as a DIVX movie to play via a DIVX Player.
Just use a different piece of burning software. I've never used the software you talk of, but Nero is a piece of cake to use.
Suggestion:
-Make sure your media is blank.
-Make sure the capacity of the media is large enough for the file.
-Check over your settings.
-Be aware that it will NOT play on a DVD player unless you re-encode it .VOB format first.
-Check the correct codec's are installed on your client.
Not all DVD players will play Divx format.
If you have a divx file and want it to play on a dvd playerthat wont play divx then it has to be converted to dvd. Wouldnt know how to do this, or even if it can be done, but it will take a long time to do it.
