DIY Aerial
  BMW 330ci
I've heard and seen a few people have DIY'd their aerial, basically chopping the long bit off the top. But does the radio still work, and does it work clear ?
I'm thinking of doing this, but dont want to loose the radio TBH.
Thanks.
  1.2 Dynamique
I wasn't too bothered about if mine worked or not so I just hacked it and screwed it back on.
I tried the radio after and it worked!...Cheap mod, check my progress thread to see how it looks if you like.
  BMW 330ci
you can use warm water to soften the top up and pull the bobble off then cut the aerial and stick the bobble back on. i have no idea how it work afterwards or....
buy this .... http://cgi.ebay.co.uk/ws/eBayISAPI....271766&ssPageName=STRK:MEWNX:IT#ht_1194wt_905
i just fitted mine and it works perfectly fine and looks better too. i had to cut about 5mm off the thread though so that it sat flush
oo wicked cheers for that, might try it, not sure just dont wanna do it and then find that the radio dont work lol.
oo wicked and ok then will do (Y)
ipodsandguns
  GW X200 CUP
This method has worked fine for me on all other cars by the 200, huge drop in quality and coverage once I chopped that arial down.
  BMW 330ci
so couldnt you pick up channels that good then ??
Well if it doesn't f**k knows how my radio has been working the past two years :rasp:
Mine is about half its original length
and oo haha, think i might give it a go, i suppose if it goes terribly wrong like radio dont work, will have to buy one lol, just cba atm.
