Door speaker upgrade problem
Car  2004 1.6 clio
Found a slight problem while wiring up the new speakers in my Clio, I'll be running new front components and 6x9 into an amp in my boot.
I've done the wiring on the passenger side of the car but having trouble with the driver side, I've followed the speaker cables back from the speaker to the plug but can in find the green and grey one on the plug, other one is just gone and when I go to find it on the inside of the car to wire it to the amp instead of the head unit, it just isn't there, the other side has 2 light skin coloured cables instead.
I've already tried cutting them and testing to see what they did but it caused all electrics in both doors to stop working
So now I'm stuck, if anyone could explain in detail or show pictures of which cables to cut then that would be great
Also I'm using the standard head unit so I have bought an adapter kit so I can run the amps red and white plugs into the back of head unit with no troubles, only thing is I don't know which cables to cut and reattach
This is my first time working on a Renault and it's been rather difficult compared to my previous projects
Sorry for the essay but I just need to know exactly what to do
