A Friend (or something padded, to put under the door to take the weight), Pointed noise pliers (removing clip on pin), a hammer, ideally a door pin removal tool set (basically like a long center punch and a rod with a "U" at the end to get under the head of the pin), failing that a long screw driver. The pins can be tight so use a bit of pentrating oil and heat if you have a small gas iron......
