drive shafts
  Renault clio 1.4 16v
remove the wheel, undo the drive shaft nut, remove lower ball joint and pull the hub off the drive shaft you may had to take the caliper off to do this, and the inner end off the drive shaft (gear box end) is held in with 3 13mm bolt remove them before you do that drain the gear oil because when you take the drive shaft out gear oil will come out 2
