White Sti Hatch
Ok so ive just picked the car up from the dealers after getting other faults fixed but the main one was the drivers side window and the prob was as follows
You press the button to lower the window holding it down and after say a couple of cm it would stop dead press it again it move again maybe a lil more the stop would do this all the way down and back up again, But some times id be luck and it would work perfectly fine go up and down smooth as silk 10 times in a row but 2 mins later same problem.
I told this to the stealer and the said theyd sort it so went picked it up work fine when i tryed it later on buggered again, this is a long shot but anyone have a clue what could be causing this ??
Its a Mk3 Dynamique S btw any help would be great, just so i can say when i take it back again you might wanna try this or that![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
