Drying Aid/Finishing Spray! Any ideas what to use?
  106 GTi
I use Meguiars Last Touch as a drying aid as it is cheap.
As a QD proper Britemax, Clearkote Quickshine or Sonus Carnauba Spritz.
  Mito Sportiva 135
Rich did you like the Britemax QD as much as the Sonus stuff? I have loads of Last Touch but like something a bit better for using on my own after waxing...usually usethe Sonus but considering trying the Britemax after some good reviews on it.
  16v Dynamique
As Rich said, Last Touch for drying aid as it is the most cost effective. You may then want to give the car a wipeover with a more "special" QD. I use Zaino Z-6.
Gally
is it best just to finish your waxing then spray a panel at a time with last touch then wipe off? what is the last touch for?
apologies for the hijack.my bad.
gal/
  106 GTi
I tend to wipe the car down after waxing with a detailing spray to get a perfect finish - will remove any wax smears or bits you may have missed.
Can also be used to remove an light dust the car may have accumulated in the garage, odd finger prints etc and also to aid drying by adding lubrication to the paint.
Gally
:) thanks very much for that rich.helpful as always.
gal/
  Fiat Coupe 20vt
Meguiars #135 is definately worth a mentiuon as well. This is the trade version of Ultimate QD and leaves a ridiculously slick finish.
  106 GTi
How does that work out cost wise, as cost effective as the Last Touch ?
Can it be watered down/used for drying Tim ?
I am getting low on last touch, use a replacement for or in addition to ?
  Fiat Coupe 20vt
No it's definately not as cost effective as Last Touch unfortunately or as versitile and you can't water it down. It's £29.99 a gallon, but as a QD/spray sealant it's in a different league.
  106 GTi
Ta - I will stick to the last touch then.
Though could the 135 be used over a Carnuba ?
