V
valver pete
Anyone recommend one to get? And any tips? Always done it by hand but thinking there must be an easier way with better results!
FM-AVA-696 said:
brazo said:If the panels geting so hot you have to throw water over it the person wielding the polisher should be fired!!!
FM-AVA-696 said:explain? panels always get that hot when mopping with cutting compound. cant be avoided other than cool it down with water
brazo said:Only when you use a rotary at too high speeds. By 'mopping' a panel at high speeds it creates huge variances in paint thickness by trying to cut the paint too fast.
I have cut the worst defects out of paint by using a slow cut tecnique which involves about 1200rpm and the panel only becomes hand hot. This is also perfectly safe on edges. The panel simply does not need to get hot!!
Rich said:The above is only good for applying and removing wax, it has no power to correct paint defects.
