Yep it can be done.
However forget it cost wise.
You need the dash panle the pipe wor the condensor you need to get a new Aux belt and pump fitted you need to get it all wired in with the heater unit. Then you could either
1) Have the ECU programmed by Renault as if the car had aircon/climtae (since cars with it have to switch the unit on and off starting and off at high rpm and increase idle).
2) Bodge the above
3) A real bodge and do it with switches in the cabin ir switch it off when car starts etc.
