Quote: Originally posted by BenR on 04 February 2004
difference between F7Rs, not Rs and Ps ben lol.
And polished inlet parts????? where?
resin coated?
The blocks are quite differnt in their casting, strenthning ribs mostly. and some bolt holes.
Front covers are the same though.
cranks are different parts (willy ebing the diesel one), but physically the same.
rods the same.
Pistons are the same (depending on markings) as with rings.
And the sumps are different. The willy has a baffled bit.
And when you ask about balancing, you cant ever say how much your going to take off. It totally depends on the part weight and balance.
Anything i missed out?
well that pretty much covers the difs ive seen too, mainly being the stregnthning veigns(spelling?) at the rear of the block
iv also been told that he crank on the willy is def diff to the megane, and both are def diff to the diesel one................lol
seems to be so many ppl offering their services without actually knowing what the difrences in the engines reallyare , i.e in relation to tuning
oh and pistons..........the arrows on the megane are facing the oposite direction to the willy 1s.....i think,neither engine seems to have had a rebuild
as for wanting to know how much weight we were talkin in the litening/balancin thing, i was just wondering how much theyd lighten the flywheel by, obviously the rods can only be lightened to what the lightest rod weighs(without compromising stregnth a great deal), an u not gunna know that until uv weighed them all lol
as for te flywheel, mine weighs 5.4 kgs with all he bols, jus wanted to know how light they went with em cos they not exactly the heaviest to start with are they? lol
and the heads are totally diffrnt too hehe............which would explain why they make dif torque/power .............and by lookin at them the inlet valves on the megane seem to be slightly bigger than the willy 1s .............but the inlet tracts is where most of the dif is noticable, which would explain why the megane head is better for use with throttle bodies when youve seen it
