faulty subs
was lookin at my friends subs today,
i took my multimeter across both terminals of the speaker, and found there was no ressistance in them.
does this mean they are fualty?
Andy
Put a Double A batter across the terminals of it. Please use wire to the + to the Positive of the speaker and the - to the Negative of the speaker.
If the speaker makes a pop or a noise then generally its all ok to use.
i havnt done the battery check i will try it tomorow thanks for that.
im sure you should get a ressistance in it if they are off, would just like it clarified.
Andy
looked for any signs off loose wires today around the cone and all seems to be fine, even if it is loose at the cone it must be very hard to repair, as u cudnt solder it on as it would burn the cone
Ya there should be reziztance in a sub one way or another wat reading you getting all zero's or a one in the left corner.
If ya put a battery on the terimals only do for a quick second as speakers aren't designed for dc voltages so this can cause damage
ye hes prob better just buying new ones, will do the battery check first anyway but i dont think it will work.
cheers for the help guys, anymore comments welcome
andy
dependant on what sub it is they can be reconed, but thats onlt high end ones, what subs are they?
probably blown them, they are crap, ive got a competition sub up for sale, £90 or 2 for £170
