Feels like a flat tyre !!
  RenaultSport clio 182
Bah Humbug !
The 182 is not well and maybe you guys can help!
When I turn the steering wheel it feels and almost sounds like the nearside front tyre is flat. Is this a suspension problem? I don't want to go to any garage in Milton Keynes until I have a fair idea of what the problem is.
Many thanks all
:S
I have just spoken to Sutton Park and he claims to have a 182
He says the fault is perfectly normal as it is 'dif wind-up'
Is this true or a Wind-up?
But he does say to get the spacers fitted to the suspension.
Any thoughts?
  Rsport182Cup'd
mine does it all the time, when i asked i got told that it was to do with the diff and the traction control, it does feel strange until you are used to it, i bet it only happens if you are pulling full lock and at a crawling speed.
Has anyone noticed the suspension tops move when the steering wheel is turned?
Yep stearing tops move when the wheel is turned its the desing if they catch if makes the noise thence people space them to move them away from the body.
I'dget the sapcers if your catching otherwsie start looking at worn top mount bearing etc.
