Fitting ITG Maxogen
Ash J
  Sunflower Ph1 172
Hi guys
I shall be fitting my ITG Maxogen this weekend to my Clio 182.
I just want to be prepared. It will be a fairly easy swap I know, but my only question is regarding something called an acoustic valve? I've seen a lot of people refer to it when fitting panel filter/induction kits etc?
Firstly, I'm assuming my car has an acoustic valve? Secondly, am I correct in thinking I won't need this with the ITG? If that's the case, is it obvious to remove it? And do I need to block anything off or anything?
Ash
  Mazda3 2.2D 185BHP
Just forgot its there.
Unplug old pipes from stock airbox. and just ignore it. Wont do anything if there is no pipe connected to it
Ash J
  Sunflower Ph1 172
So there isn't anything that needs blocking? Read about a pipe or something?
Cheers for the help.
