flashing lights
Car  182
hello people need some help driving to work on sat morning about 630 still preety cold and just before i get to work the abs and service light comes on along with the slippery road sign any ideas why ????
turned car off and restarted and everything was fine anyone no what this was/is ???
Its a sensor on the brake pedal, give it to Renault and theyll fix it its a common problem. If they claim to not know if it then get them to update there technical notes as its there.
Had mine in because of the ABS an serve lights had been on alot (not all the time, but often) but they wasnt on when I took the car in. They said in the events if showed a really old error but they doubt that was it as it was well before I reported the problem, so she said they will reset it and see if the error has appered in the log when I take in back in in like 2 weeks time, but I cannot get the lights to come on again! Dont know if its because of the road conditions are not as bad or something (seemed to come on when on ice or really wet winter roads)
Quote: Originally posted by quickshift on 06 December 2004
hasnt happened again since sat thou ???? should i just leave it ?
Its a common fault and theres a known fix it probably will only happen randomly so might as well got it done before it annoys you by turning up again.
