Matt e
Had this problem a few months now, when you press down the accelerator it seems to lag a bit before the engine revs. And some when you pull away it sort struggles, almost like its miss firing before it gets back to normal. it doesn't matter if the engine hot or cold it always seems to have the same problem.
the things ive looked at so far are, cleaning the tdc sensor and changing the throttle body, ive also had it on diagnostics but it doesn't show any errors
what could it be? lambda, injectors
