gaitor suround
hey up guys my gaiter surround has broke and is now loose when i go into fifth or reverse..how much is a new one from renault cheers guys
Re: gatter suround
just under five quid now, as the b******s at renault put the prices up.
Re: gatter suround
Yup, £4.95 when i last got mine.
Not very expensive and they are the same for all the MK2 clios - no "special" ones lol
Re: gatter suround
cheers guys that aint to bad how the hell do you fit the bugger do you have to take the gear nob off?????
Re: gatter suround
Nope
1) Unclip the gaitor
- You can remove it by taking out the ashtray then sliding your finger thru the gap to unclip gaitors base plate.
2) Lift gaitor upwards so its inverted up
3) You will see a small zip tie, this will be tied round the gear knob base, cut this off
4) Baiscly reverse of above apart from you will have a new gaitor with a new zip tie which will need to be zipped and trim the excess.
Re: gatter suround
No probs
Itl be quite easy when you actually look at it.
Good Luck
Re: gatter suround
cheers mate thanks for your help on this one!!! can i just double check this is the plastic surround that the leather sticks to aint it? not the leather it self cos mine is fine just the base which has come loose cheers
Re: gatter suround
clidge said:
chrome surround.........mmmmmmmmmm any pics mate?
give 5 mins ......................
...some time later
Re: gatter suround
lol cheers for pm mate thanks for pic where did you get that from do they do it in silver rather than chrome and is it easy to fit cheers matey
Re: gatter suround
drill small holes for it to screw down better ........... any major motorsport place should get em on order for ya .... dunno about silver 1's
