Gear Shaft Sleeve
I think youll find the clio has lift up reverse, and i think, not 100% sure but i think that you cant fit these, cus the lift up reverse collar is there
i had that problem like Lunner said, i jus took the screw part out of the top, laccy band around the top, and gear knob sits over the top! :D
mines was momo, but same sorta thing
I think you can do it to have a check you can pull up the surround around the gear lever and have a look at the mechanics behind it to see if you can do it.
It says it works with the richbrook uni hex gear knob which i have so i assume it will be ok.
I just wanted to know how easy it is to remove the current gear shaft and how do i go about it.
Also how easy would it be to replace the gaiter around the gear knob, simple?
Dead esay the bottom of the cover come away quite easily
I dont know too much about new style clios but I would imagine that the Richbrook sleeve fits over the existing gear stick with no need to take anything off. Apart from the gear knob of course.
Could always give them a bell 020 8543 7111
Can it be removed without damaging the gaiter?
DO I just pull away at it :)
Pull the rubberey surround bit from round the gear stick at the botom and youll be able to see the hidden bits of how the gear stick is stuck on.
I cannot understand how its help on for certain in the drawings Ive got here.
