Hutchie said:you can always put 5th gear out of a diesel box in
i plan too, and you dont have to take gearbox out either, just take end cap off, carefull not to break the oil feed
I dont think you can replace individual gears on the JC5 to alter the ratios.
yeah, but diesel ratios are rubbish
how so, you not going to get more usable power lower down the revs?
Which box fits straight on steve?
why?
Mk2 boxes are interchangable between models if thats what you mean, same bolt/bellhousing pattern
Because stan at ADP tried and couldnt do it. I think you can do 5th and thats it. So pretty pointess. I was under the impression the input shaft is one unit, except for 5th.
what's the ratios like in comparision then?
by longer I presume you mean that you can get more speed in the gear before changing? I suppose for track work though the box needs to have shorted gears?
Do you use the diff that comes with the box? Presume the DS are originals too?
I actually find them more suited to large powered turbo conversions.
Yes mate, for track work you need a gear box that suits your power band, high revving N/A throttlebodied and cammed engines tend to have a narrow band at the top of the rev range, so longer ratios would drop you outside of the power band on gear changes, where as turbo cars tend to have a broad spread of torque/power so you can use longer ratios and cover a larger spread of speed.
For example in mine with the torque I can drop as low as 10mph in second and then hit 140mph in fourth where as in a a highly strung N/A with a stock box you may have to drop to first to get decent pull from 15mph and will obviously have to be in fifth to hit 140mph.
The drive shafts are 182's coupled to a stock box/diff.
I said you can only change 5th, the rest are fixed as it's a one piece integrated input shaft.
ahh, but that's because you have a small turbo, run something that will make large power and the rev drop 1-2 will kill you. Same thing for the guys running big cams.
Yeah but have you seen my 4pots? They are close ratio 4pots.
any gear boxes with short ratio's for on the track?
Stick the jc5 002 out of the old turbo diesel renault 19 they have tapered bearings just like the 172 box and well able i had them in my 172 and clio 16v was able to get 150 mph no bother in the clio16v and ran out road at 156 in the 172!!
You want to change final drive really ben. Get a quaiffe in there with modded crown nice and cheap
