Having problems fitting my lexus lights
I have got one on , but the left one doesnt seem to fit right, it sits to high and needs to come down a bit , but it wont.
The boot shuts but it looks wrong as the right side is correct......has anyone else had this problem?
if its a facelift model and a certain set of lights, i had to chop a wee tiny bit of plastic of the bottom of the light mounting to get them on properly, came off no probs with a pair of clippers :)
take them right off, and check youve got them seated right, and whatever before putting the thumb screw into place..
  Bumder With A Buffer
I fitted some to my valver and had same sorta problem, i found out it was coz it wasnt seated correctly. Theres a sort of metal flange at the bottom of boot ware the light sits and the lights HAVE 2 be seated in this correctly. U mite find its slightly bent and u may need to pull it out just a tiny bit.
Hope i explianed that ok????
