Headlights
Ignitor or the ballast might be on its way out. Worth swapping the ingitor over from one side to the other to see if it fixes the problem (providing its one headlight faulty and one working). If thats the case and the problem jumps from one headlight to the other then its the ignitor if it stays on the same faulty side then it proberly is your ballast pack. If its both it may be a dodgey relay switch or moisture behind the bulbs?
