help needed from 1.2 8v owners grande owners and mechanics
hi everyone
right this is this the issue im 16 and wanted a project for my 17th so my dad bought me a Renault clio grande 1.2 8v with the cambelt gone.
so had it repaired cambelts done
valves bent so had all new ones
head skimmed
then turned it over and perfect started first time
then as it ideled down on tick over the engine started to rock back and forth
so took it for a good run no power loss or jerks or clunks
but as it idels it sound like its misfiring but when you drive it its smooth
so we change the coil leads not pack no change
spark plugs twice no luck Bosch and currently NGK
cleaned throttle body no change
full service no change
thought it was sipping petrol put 20 quid no change
so help if anyone of use have had this issue before can you please help of how to fix or are 1.2 8v genuinely like this because when the engine rocks the car rocks along with gearstick
mechanics I need help
people who own one of these is this normal
things I haven't done is
changed throttle body
new coil pack or different one
botton engine mount (but if it is why does it sound like it is missfireing)
help
kind regards
McGherkin
Macca fan boiiiii
Just upload to youtube and then put [video.]Youtube URL[/video.] in a post.
Sounds like coilpack tbh, if you can find a mate/relative/CS member with a 1.2 8v nearby you could try swapping the coilpacks over to prove it?
McGherkin
Macca fan boiiiii
It idles slightly rough (mainly sounds a bit rough) when first started and cold, but once it's warm it's perfectly smooth. I'm fairly sure my lower mount's gone at the moment and the gearstick does move around a lot because of it.
