Help Needed Quickly!
  RS MEG, 182
Hi
I noticed i had a brake light out, so i tested the light bulb, and after moving the cluster about, the bulb came back on, so it must be a faulty connection somewhere.
However i get back in the car and drive away, and the speedo and rev counter are dead, and nothing lights up on the dash. The indicators work but theres no clicking sound, which i think comes from the relay. Could a fuse of blown somewhere when i was messing with the rear cluster? If so where is the fuse as its not labelled up on the dashfuse box. Its a MK2 clio
Please help
Rob
  Golf R/Leon FR
yeah dude sounds like you've blown some fuses, i had the same problem too, when i changed my lights to the mk2 ph2 lights. best thing to do is have a look at all of the fuses and see which are blown, the little metal strip in the middle will be broken. then its just a case of replacing them. renault supply fuses think they are 20 - 30p each iirc.
  RS MEG, 182
Cheers Phonenixy. I had a look at the fuse board earlier, turns out the brake light fuse had gone, which must be on the same circuit as the dash supply.
