Help Sub woofer.....Help
  Clio RS 200
Hi there is there anyway of conecting a sub to an original head unit in a 05 182.......elp help help:)
  renault clio 172 2002
yes there is you need an amp with a high gain input so you can put the speaker leads from your head unit to your amp and then put a sub off the amp
  Clio's
you can also get one that sticks into the slot in the back of your headunit which is for the renault CD changer!
  Evo 6, E92 320d
^^^ agree with 'matt trev' , the 1s ive tested will do the job but theres deffinatly better
