clio 182
well basically tonight i was moving my electric window switches from the door to the centre console so i can fit my carbon door cards.
all i done was split the loom at the connecteor between the door and the car, pull the wires out that are for the windows at either side, then made new joins inside the car so the switch would reach the centre. (hope that makes sense)
whilst doing this i removed all the electric mirror wires just from the door as they are not needed now.
the windows work perfectly but the problem is now my window wipers are on all the time no matter what setting i put them on!!![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
so.....is there anything on the door loom that could have caused this? and if so how the can i fix it!
any help at all is appreciated!
thanks!
thanks!
