Help with Wireless.
  RB 197
Ok, so i 'think' i've set up my new wireless router correctly, it's up on my notebook etc but when i try and connect a box pops up saying
''Windows was unable to find a certificate to log you onto the network Belkin_G etc...''
What is a certificate for one?
Also on the wireless connection box it says 'validating identity'
Confused.com
Christopher
  Z4M
Go to Start --> Programs --> Accessories --> Communications --> Network Connections --> Right-click your Connection and select Properties --> Click on the Authentication tab --> Disable / uncheck the option IEEE 802.1x authentication for this network.
Now, try to connect to your Wireless network; are you able to? (Note: you may need to restart the computer.)
  RB 182
connect to the router with an ethernet cable, then connect to the router, should be 192.168.2.1 , type that in your browser and you should get the setup page for the router , you can change wep keys etc all in there
  RB 197
As if by magic *am not joking* after 2 hrs of frickin about it magically says 'connected' ?? Thanks for trying anyway helpful people x
