Help!!
  E60 diesel powah
Jus re-wired my sub and amp because the amp kept goin on and off..but its still doing it!! any ideas? everythin is wired properly! Amp just goes on...off...on...off...etc
thanks
Immi
Bluebeard
  Whichever has fuel
I'd just put in a new one. It doesn't have to be thick.
You could just try it using an old bit of electrical wire just to see if it cures it, if it does, buy a new remote lead. If it doesn't cure it, you've saved some dough! :)
  audi a6 3.0tdi
did you try your earth is it to somewhere good with a good contact to the bodywork ie no paint in the way
Pep
  M2,XJS,S1000RR
mine did this, ran the earth back to the -ve on the battery and it worked a treat.
couldnt find anywhere that would give a decent earth.
