help
MatthewR
well i went to my car this morning, and there is water on the ceiling, down the A pillar and a patch on the seat.
looking around thar corner of the car and it seems the windscreen trim (the black rubber) is loose, could this be the cause of it?
any other ideas?
It's loose on most tbh, I doubt it's that as the water can't drip upwards to your roof lining... Isaac Newton said so.
Do you have a sunroof? Most likely the cause, or your aerial lead which follows the path you described.
MatthewR
yeh iv got a sunroof. i figured it might have just soaked up from that corner :S ip put some vasaline around the seals on the sunroof and windscreen to try and repel the water for now untill i get a permanent soloution.
what would you call it then rampantrabit?
