Horn wont work
  BMW 118d
Have a play with the connections. My girlfriend's clio's horn stopped working when it went in for its MOT. The garage just cleaned up the connections and now it works fine.
  Ph1 track 172
volt meter on the connection,
if it shows nothing, then check fuses and wiring,
if it shows 12v then get a new horn.
  172
it will most likely be the earth connection as it has happened on every clio I've ever known... as above check fuses, then try cleaning up the connections but before you go & buy a new one run a wire directly to the battery & another to an earth to check if it works.
