How do i get camber?
Just wondering how i would go about achieving front camber?
when i had my coilovers fitted the guy suggested i should use camber bolts, but i just nodded my head.
what do they do exactly? and would they give me slight front camber?
cheers,
Nick
Sometimes coilovers are slotted so you just loosen the bolt and tretightne it in a slightly different position.
If not and I'm suggesting you don't have a slotted hole on the dampers as thje mechanic pointed out then by using anundersize sort of bolt you can move the strut and damper about
